over heating issue
Old Sep 14, 2010 | 11:32 AM
87montelS87's Avatar
Default over heating issue
hey everyone, i have a problem, maybe someone knows how to solve it or has an idea on wat i can do. i have an 87 monte with a stock 350 out of a 80s corvette with 305 heads, edlebrock intake, holly 650 carb, msd wires, dist., n ignition, turbo 350 trans, 22in electric fan and a posi rear end. now im not running the stock fan off the water pump n i dont kno if i should or not. ive changed the thermostat twice n it still over heats. if theres something im not doin please let me kno!
Old Sep 14, 2010 | 12:11 PM
Blazed SS's Avatar
IT HERTZ
Ok make sure the it is a pulling fan not a pushing fan you can tell by turning on the car and fan ad put a pc of tissue paper on the front it should suck to the radiator if the fan is wired right and is placed right on the radiator (motor side is pulling .bumper side if pulling) on my 1 Chevy truck i had switched out from the belt fan to electric fan and the guy that put the new fan on had wired it wrong so it was trying to push the air though the wrong way (instead of pulling the air though the radiator ) and gave me a sporadic over heating problem the only other thing you could look at is check the cfm of the fan you may need a a twin fan set up to move enough air though the radiator
Old Sep 14, 2010 | 12:18 PM
i did check before n it is pulling thru the raditor, so i have no idea wat could be the issue, im also tryin to get more power out of it with out spending alot of money, any suggestions?
Old Sep 14, 2010 | 12:38 PM
Blazed SS's Avatar
IT HERTZ
fulush it out real good you may have a plug or a air pocket some where . With out being there that would be my next step and it is cheep to flush it out
Old Sep 14, 2010 | 11:15 PM
ok i will deffinitly try that n c if it works, u have any idea how i can get more power out of it?
oneandonlydylawn
Jun 2, 2013 02:15 PM
clasbya
14
May 28, 2010 05:34 PM
connersdad19
May 29, 2009 03:24 AM
sprfrk2005
May 20, 2009 09:15 AM
bjar61
Jan 7, 2009 04:48 PM
