I'm So Pissed!
I'm So Pissed!
OK so I got the new Crack sensor put in. Had the code for it so I got it changed. And had the relearn done. But she still gurgles. Drove her 10 miles then the Check engine light comes on. She's acting like she's missing on a cylinder. Bad plug or bad wires. Gotta get on Pepboys case. What it was doing is what was on the work order. I don't think they took her for a test drive after installing the sensor.
Well she goes back time them in the morning. They open at 9am. I'll be there at 8:45am. And I'm waiting for it. I mean, am I Wrong for wanting it either fixed or to tell me what the problem is so I can figure weather I can fix it or I need them to fix it for me? I have so many 4 letter, French words I want to use right now, But I'll remain P.G. and just say, I'm so beside myself. I Wrote Out the Work order so I know what it said.
1) Crank Shaft Sensor
2) No Power, Bogging at Half Throttle, Shuttering when shifting, Rough Idle.
So wouldn't you check for that stuff if it was on the work order, or would you assume the problem was fixed cause the sensor was in?
Did I say I was PISSED?
Time to stop whining.
Sorry for sounding off in any ears who choose to read this!
Sorry JC to hear they didn't get it right!
Good Luck in the am! If they still don't get it right/tomorrow....That's when you can stuff your boot up there behind!
Good luck...Hope it gets straightened out for you!
Maybe somebody will know what you need ..
Thanks guys. I know not to be pissed when I speak to them. They already know I'll be there. I still only trust them to put tool to my car when I don't have the proper tools, aka a Lift! And this is the first time in 5 yrs and 3 cars they have disappointed me. I'll put pressure on them just by being there. Subtlely influence them to get it Right!
I would trust her to get me to Florida and Back now!
After spending 3 hour waiting at Pepboys, Jeff, the mechanics apprentice at the Nissan dealer and part time mechanic at Pepboys, put the big expensive Computer on my car and took it for a test drive. He came back and said he heard and felt it misfire. And that the big expensive computer said it was cylinders 2 & 5. I said that was the center coil pack. He said he wasn't sure of the firing order. But I said I know those 2 cylinders fire off of the same coil pack. So I bought all 3, put them in and Wa La,
My YelloJAC NOW RUNS BETTER than the day I bought her. I feel like a kid in a chocolate factory with no Willie Wanka to stop me!
So I drove and ran her for 3 hrs, some Hard, mostly the way I normally drive, No Check Engine Light! And all sensors and fuel injectors checked out Good on the Big Expensive Computer.
I've waited for this day for 15 month and 2 days! Wow, all the sensors, plugs, cat and everything else I got bloody knuckles replacing, was all to get to this. I never thought this day would come. Wow I feel good! I Hope all you guys and gals who have difficult times with your Montes, get to feel this Monte Carlo Hi! It's Great!
MyIntimidator
12-03-2007 06:35 PM
