How to get to the shift soleniods?
Old Sep 6, 2012 | 02:29 PM
silentsloth98's Avatar
Default How to get to the shift soleniods?
Ok I was driving the other day an everything was going fine then all the sudden after stopping st a light I go to take off an the car takes off like normal but wouldn shift tell it got high on the rpms then i let ofan it shift once I touch the accel. Again bu then it just hurryed trough the gears it seemd an goes in to od at like 30mph sfter doing a pan service an new modulator nothing same thing still. Mechanic told me more then likely was the solenoids. Sounds right an if so how do I get to em?
Old Sep 6, 2012 | 02:57 PM
SupplySgt's Avatar
If I recall correctly you have to pull the pan to get to the solenoids. Been a while since I've worked on a FWD car though so I don't know how different they are from the RWD trannys.
Old Sep 6, 2012 | 03:52 PM
Turns out when mine started behaveing like yours...I ended up getting it rebuilt...I even had the fluid and filter changed every other year! Even though I took great care of it...things do wear out....Cost $1000.00
Now it runs like the day I bought it from the Dealer....
Just curious:
When it did shift.....did it feel like it had a shift kit? Thats what mine did....
Old Sep 6, 2012 | 04:26 PM
I dont think you can get to them with the transmission in the car but im not 100% sure
Old Sep 6, 2012 | 04:31 PM
nitehawkjcb's Avatar
You have two options.
1. Drop half of the cradle and access the side cover of the tranny that way.
or
2. Pull the engine & transmission and do it out of the car.
JaxJim
Dec 22, 2010 12:11 PM
Frosty LS1
Aug 24, 2009 02:14 PM
88ss408
Jul 24, 2009 07:44 PM
fastback4
Jun 2, 2007 07:05 AM
fastback4
May 3, 2007 03:31 AM
