hot engine bay?
Old Aug 4, 2014 | 12:16 PM
Jokers1995's Avatar
Default hot engine bay?
Another stupid question. But with this car, after I drive it and pop the hood, it is really hot under there. My engine isn't running hot and I have coolant, but if you touch the support bars on the side, you can't hold onto it, it's that hot! Is it like that naturally or do I have a problem?
Old Aug 4, 2014 | 12:21 PM
turbo monte's Avatar
I'm wanting to say it's fine if coolant temps are fine. Engines and exhaust get very very hot to touch
Old Aug 4, 2014 | 12:24 PM
Your engine runs at 195 degrees on a normal basis. So you can imagine everything does get very very hot.
Old Aug 4, 2014 | 01:29 PM
Jokers1995's Avatar
Ok. My ls never had this heat! That's why I was kinds of freaking out!
Old Aug 5, 2014 | 09:59 PM
michelob's Avatar
I have noticed the same thing in my '01 SS and I also wondered if it was just me or normal. Sounds like its normal now since I'm obviously not the only one.
Old Aug 5, 2014 | 10:03 PM
02paceSS's Avatar
Mine is the same way you should be ok
Feb 1, 2013 07:35 AM
xrook5x
Sep 10, 2007 07:22 PM
ExplosiveSoundz
Jun 19, 2007 12:29 PM
saluteTOme
Jun 2, 2007 11:30 AM
04MonteLS
18
Sep 14, 2005 08:35 PM
