Hey guys PCM Question
Old Mar 25, 2011 | 11:58 PM
needasmoke24's Avatar
Default Hey guys PCM Question
Ok 96 monte, 3100 can i just swap pcms with the same year and engine? will it have to be programmed? any help appreciated... oh and will it affect VATS system. Thanks guys
Old Mar 26, 2011 | 07:41 AM
The PCM needs to be programmed with the VIN in your car to work.
Old Mar 26, 2011 | 12:27 PM
Crusader SS's Avatar
Another problem with swapping stock PCM's is that they are sometimes locked (depending on year) from GM... So entering your cars VIN would have to be done at or by a dealer... Other members here might have more detailed info... Good luck...
Old Mar 27, 2011 | 10:56 PM
Default thanks guys
Hope to find the answer, may have to be changed...
Old Mar 27, 2011 | 11:05 PM
nitehawkjcb's Avatar
It might work, you might need a case relearn, or you might need to get it unlocked
ThePCSurgeon
Dec 4, 2013 04:20 PM
newkidonblock
Feb 8, 2011 12:46 AM
sam1120
Sep 10, 2010 12:22 AM
Stackz510
Aug 16, 2008 12:01 PM
J.Blac757
Oct 11, 2006 10:34 PM
