"Help Me Please: Top swap, wont start ? ? ?"
Stock but tables are all already tuned for the l67 stuff, we tried unplugging the MAF. Its definitely a timing issue.
Not sure if a topswap takes the same timing as an L67, I would imagine it would though. I have about 20* at idle and 18.5* @ WOT FWIW.
Good luck narrowing it down, patience is key. I had about 8 hours into a timing belt replacement before and had to tear it all down again because it was one tooth off. Relax and you'll get it figured out.
Hi Brock, "If first you don't succeed, try, try again" ~> I've been trying to succeed for over 22 years
& I'm still try'in : )
Good Luck 4-Sure.....*Keep us updated `ok
![EEK!](https://montecarloforum.com/forum/images/smilies/eek.gif)
![Cool](https://montecarloforum.com/forum/images/smilies/cool.gif)
![Roll Eyes (Sarcastic)](https://montecarloforum.com/forum/images/smilies/rolleyes.gif)
![Mad](https://montecarloforum.com/forum/images/smilies/mad.gif)
![Confused](https://montecarloforum.com/forum/images/smilies/confused.gif)
Hi `Brock, we live & hopefully we learn (I don't always : )...
I hope that you nightmare ends and that everything gets put 2gether....Wish you GOOOOOOD Luck 4-RealSure....
I don't know `if the below will help, but it will fill in some space on this post : ) Peace/Out
Removing Crank Pulley - 3.8L V6 Supercharged (L67)(L32)
19 posts - 6 authors - Last post: Jul 20
goes back on by you lining it all up and impacting it back on with the crank bolt. dont shear the keyway and key by not having it lined up ...
www.grandprixforums.net/removing-crank-pulley-34053.html - Cached Engine turns over but will not start - 3.8L V6 Naturaly Aspirated ... - Oct 3, 2010
Harmonic, Balancer, Crankshaft, Sensor - General Tech Discussion - Sep 12, 2010
Car wont fully start without giving it gas... wtf - 3.8L V6 ... - Jun 15, 2009
Installed Overkill PCM - 3.8L V6 Supercharged (L67)(L32) - Sep 8, 2008
More results from grandprixforums.net »
schoentges16
02-27-2021 06:43 AM
BrandonStebing
07-25-2014 11:03 AM
00monteSUPRSPRT
01-07-2011 03:18 PM
