did a top swap an (wont start)
Old Feb 8, 2013 | 11:29 AM
Dam20735's Avatar
Default did a top swap an (wont start)
i did i top swap 3800 to 3800 supercharged changed the starter an now it wont start is there aint tips anybody know that i might can check to get it to start?
Old Feb 8, 2013 | 11:33 AM
`Hi Dam,
The only thing I can suggest is to check out all your power connections to see if they are getting power ?
Also, check back on your thread ? & see what our expert tech member's suggest...Wish you good luck & a running Monte Carlo.
Old Feb 8, 2013 | 11:44 AM
what year?
Old Feb 8, 2013 | 12:24 PM
Dam20735's Avatar
Originally Posted by trewyn15
what year?
02 monte carlo
Old Feb 8, 2013 | 12:25 PM
Dam20735's Avatar
Originally Posted by Space
`Hi Dam,
ok thank you
Old Feb 8, 2013 | 02:01 PM
PacerSS's Avatar
You gotta give me more to work with here. Is it attempting to start at all? Is it clicking? Do dash lights illuminate...if so which ones stay on? Is your PRND lights working?
Old Feb 8, 2013 | 02:27 PM
Dam20735's Avatar
It's trying to turn over all the lights work it's just not fully starting over it just keeps cracking it misfired once an that was the lasttime
Old Feb 8, 2013 | 02:33 PM
PacerSS's Avatar
Did you swap a cam at all?
Double check the harness that goes to the ICM(the coil pack bracket) 7mm nut if I recall, make sure it's connected. Then follow that down and there should be a ground wire that's grounded to one of the 2 bracket bolts. After that make sure the plug wires are in the right order. And then check your injector connectors.
Old Feb 8, 2013 | 02:56 PM
Do you have ANY type of tune on the car?
Old Feb 8, 2013 | 06:19 PM
PacerSS's Avatar
Oh and also make sure to connect the brake booster vac line to the blower. I've had my fair share of forgetting to reconnect that POS.
