Help with head gasket
Old Feb 23, 2018 | 01:23 PM
Seggers97's Avatar
Default Help with head gasket
Just recently noticed it’s time to replace my head gasket and I was just woundering if it would be better to get a thicker one or a thinner one.
Old Feb 23, 2018 | 04:10 PM
I woudnt bother, the compression difference is nearly nothing. I'd focus more on getting a good quality gasket.
Old Feb 23, 2018 | 04:17 PM
Seggers97's Avatar
thank you just thought I would ask
Old Feb 24, 2018 | 08:05 PM
turbo monte's Avatar
Don't change the gasket thickness unless you have the heads milled or block decked. A thicker gasket could potentially throw off pushrod size length
Old Feb 24, 2018 | 09:49 PM
Jeffs02rwdSS's Avatar
Completely agree with Turbo monte on gasket thickness. If you don't get heads plained ,make sure you get the mating surface's clean I only use a wire wheel on a die grinder because it won't grind away the surface like buffing pads and usually will get into most of the crevices
Old Feb 24, 2018 | 10:18 PM
Seggers97's Avatar
Thank I’ll be keeping this all in mind the more I look into it looks like im going to pull the engine and rebuild it with better part in it
Old Feb 24, 2018 | 10:22 PM
Seggers97's Avatar
Any recommend rebuilt kits
Old Feb 24, 2018 | 11:03 PM
If that's route your thinking buy a new or rebuilt from a reputable source, they come with a warranty.
Old Mar 2, 2018 | 04:42 PM
Don't touch the bottom end, they are super strong. If you have a bottom end issue go get another engine. It's cheaper to replace the bottom end then to rebuild it.
I don't use a wire wheel to clean gasket surface do to brissles can come off and fall into the cylinder. I just use a razor blade and acetone.
