Help with a couple of things
Old Dec 24, 2008 | 01:10 PM
sprfrk2005's Avatar
Default Help with a couple of things
Hey guys just stopping by to check up on a question i had..... how often can you use this sea foam product i used it about 8 month ago you think its time for another go or is it still good? Another thing my car has alot of vibration, just wanted to know can a lower motor mount be the cause of this? and my rpms are running rather hight at about 1500rpm on idel any idea what i could be. and by the way i have a 2001 Monte Carlo SS N/A with 98,000 miles
Old Dec 24, 2008 | 01:31 PM
kweef's Avatar
Default RE: Help with a couple of things
i believe the seafoam instructions are right on the bottle... and vibrations can be caused by alot of things and so can a high idle...pretty hard to tell from here
Old Dec 24, 2008 | 01:52 PM
sprfrk2005's Avatar
ahh i c well to bad i didnt save that bottle of sea foam to check how often its suppose to be used haha o0o0 well, so venturing into another topic, like i said i have a 2001 monte carlo SS n/a with 98,000 and well what i got in it is k&n charger kit, throttle body spacer, msd wires,full custom 3 inch exhuast, u-bent delete,NO downpipe(yet), and borla mufflers.Ok got that taken care of. Fromthefollowing can you let me know which is a keeper and which isnt..
PCM Tuning-99.99
ZZP Downpipe- 189.99
Power Log(plogs)- 119.99
Hv3 High Velocity Intake Insert- 199.99
1.9 Ratio Modified Rockers- 274.99
4T65e Shift kit- 29.99
GMPP sawy bars- 74.99
Chrome plated strut tower brace- 69.99
And if you guys wanna add anything to that list of keepers that would be greatly appreciated thanks......
Old Dec 24, 2008 | 02:18 PM
kweef's Avatar
are you looking into buying these or do u already have them? are you attemptin to prepare ur engine for a turbo /sc or is this ur final mod list. if you are looking into buying them the very last thing i would do would b the pcm tune, not becuase its bad but because if u have your car tuned for certain settings and then mod the engine more your tune will b off...so do that last. besides that i liked everything on ur list. im not sure y u would need a chrome plated strut tower brace but im sure its for looks lol
Old Dec 24, 2008 | 02:22 PM
I wouldn't use it more than once an oil change- it shouldn't ever be necessary to do it more often than that. I've been doing it every 10k in my gtp.
taebryson
Jun 1, 2015 09:48 PM
Steven73
Nov 28, 2011 07:43 PM
xxtheshockerxx
Jul 20, 2011 06:27 PM
paintballerr78
Sep 18, 2009 01:31 PM
wroeber_55
May 25, 2008 03:04 PM
