HELP. 78 Starting Problem.
Old Apr 20, 2011 | 06:45 PM
jr1700's Avatar
Default HELP. 78 Starting Problem.
i purchased a 78 monte carlo Vday.
runs great like a champ when i can get it to stay on.
only thing it needed was valve cover gaskets.
so i replaced the gaskets and now
when i turn the key it wont stay crunk more than 3 seconds
what could this be?
if i apply carb cleaner it will crank and seem to idle proper. (drove it yesterday no problems.)
but if i let it sit overnight it struggles to start and when it does,
its only for a couple Mississippi's
note that ive changed all vac lines, fuel pump, & filter.
my mech thinks its a ICM problem. any ideas?
Old Apr 21, 2011 | 11:18 AM
jr1700's Avatar
anyone?
Old Apr 21, 2011 | 12:31 PM
zipper's Avatar
Have you checked the easy stuff yet like the battery/alternator/starter, and plugs and wires? Also, how's the compression on each cylinder?
Old Apr 21, 2011 | 06:45 PM
Warhorse's Avatar
EGR valve, or just maybe the dang valve on top of the valve cover. The correct word escapes me, maybe the hose running to it from the carb got knocked loose?
Mike
ww
Apr 21, 2014 08:01 AM
sws2000
Apr 24, 2009 11:27 PM
dub
Aug 13, 2007 07:50 AM
01whitess
Sep 20, 2006 10:33 AM
