HELP: 3.8 Valve Covers
Old Apr 9, 2010 | 11:48 AM
gothkid's Avatar
Default HELP: 3.8 Valve Covers
Hey guys im having troubles gettin my valve cover (i only tried one so far) off. The left wishbone mount is in the way.
Can anybody walk me threw it?
Old Apr 9, 2010 | 07:38 PM
nitehawkjcb's Avatar
If it's like an L67, you need to remove the coil bracket for the front valve cover, and you may need to remove the alternator & bracket for the rear.
Old Apr 9, 2010 | 10:06 PM
gothkid's Avatar
ahh finnaly help lol
thank you
Old Apr 9, 2010 | 10:29 PM
No problem. Granted I've never worked on an L36, but I assume it's mainly the same as an L67. Just those brackets, and then you should be able to just remove the valve cover bolts, then you should be good to go.
Old Apr 10, 2010 | 04:58 AM
RocknSS04's Avatar
It'd probably be easier to get to the back one if you rolled the engine forward.
Old Apr 10, 2010 | 10:26 AM
gothkid's Avatar
i havent gotten to the back yet, i really want to get the front one done first because thats what people see the most.
Old Apr 10, 2010 | 04:40 PM
If you have to remove the plastic coolant elbows on the alternator bracket- buy new ones first! They're prone to cracking upon removal.
Old Apr 10, 2010 | 07:30 PM
gothkid's Avatar
well i dont wanna break anything
Old Apr 10, 2010 | 07:39 PM
They're cheap, like $2 or so at autozone, I just don't know if the alternator bracket and such is any different on your car. When I did rockers on my 99 gtp, I had to remove that bracket, and I of course broke one of the coolant elbows.
Old Apr 12, 2010 | 09:06 AM
I picked mine up at Pep Boys in the self help section, got a spare set in my trunk too haha
nemesis
Apr 11, 2009 02:39 PM
Deeksta69
Apr 2, 2009 07:57 AM
2003supersport
Dec 1, 2008 01:11 AM
RocknSS04
Oct 6, 2007 08:00 PM
mentiroso
Oct 6, 2006 08:48 AM
