6th Gen ('00-'05): Helllppp!!! Tranny advice..!
Old Oct 7, 2012 | 07:07 PM
Domo01SS's Avatar
Default Helllppp!!! Tranny advice..!
Ok, so 2 issues here:
1. My tranny takes more than a second to make a 1-2 shift. But 2-3 and so on works great...! Fluid and beautiful and pink, with no signs of shavings, bubbles, and is normal level? Does anyone know how to give me good news without giving me the horrible "Rebuild" word? Lol. Because this is my 2nd tranny this year...! -___-.
2. On my first tranny, ONLY the differential broke. Which caused me to guy the transmission that I'm talking about above... . With that being said, would I be able to save that one without a rebuild? Would draining the tranny and torque converter and replacing with new fluid work? Or would that be too risky? I just figured it would be worth a shot since this tranny shifted FLAWLESSLY. MUCH better than the tranny above... Please give advice to a broke college student trying to save as much money as possible...!!!!
Old Oct 7, 2012 | 10:20 PM
nitehawkjcb's Avatar
Sounds like the 1-2 shift solenoid is sticking/failing. It requires dropping the cradle or pulling the engine & tranny.
Old Oct 7, 2012 | 10:58 PM
Domo01SS's Avatar
Oh no.... I reallllly don't want to take it to a shop. And me being a student and all, I don't have the time to read up on a do-it-yourself. How much would a good shop charge for this? I assume it would be on the level of a rebuild, since they have to drop the cradle. I know the part is cheap though. Do you have an opinion on the other Transmission that I was talking about in the post?
Old Oct 7, 2012 | 11:40 PM
The only thing that failed on the other transmission was the differential?
If so, remove the one that's bad, get an HD differential from an L67 and swap them out. You may need to get a halfshaft from an HD tranny too.
As long as the diff didn't tear up the transmission, you should be able to swap them and be good to go. Either way, you're going to have to drop the cradle or pull the engine, so labor would be about the same IMO.
Regardless, keep both the transmissions. One needs solenoids and one needs a differential.
Old Oct 8, 2012 | 10:23 AM
Domo01SS's Avatar
Ok, that's better news...! After we dropped my last Tranny with the broken diff, we checked the fluid, and there was a FEW tiny metal flakes. And when we dropped the pan, there was little to none. With the fluid still pink and pretty. Well, glad I got 2 transmissions that aren't completely destroyed...!!! I guess I can play with both of them on my winter break...!!! . Thanks for your help my good sir.!
Old Oct 8, 2012 | 12:52 PM
Any time, glad I could help.
Old Oct 8, 2012 | 05:13 PM
Domo01SS's Avatar
Just to be a little more clear about the Broken Diff. Tranny....
I was driving, when the tranny just refused to go into any gear.... Like it didn't want to catch on. Before that, it used to be a whining sound coming from it. Like a Pig's squeal. Then, when I pulled the Diff, it was chewed up. So I figured that's what it was. Mech. Told me that it was more than likely the diff too. He told me that I needed a whooole rebuild... I wish I would have just trusted my gut. I ended up spending another 1000 on a different tranny, when I could have just got a new diff. and put new fluid in there. Oh well...
kevinml86
May 24, 2013 07:50 PM
Montes4me
Mar 19, 2013 06:10 PM
slinkeey
Feb 3, 2009 10:33 AM
bluebrooks
Sep 29, 2008 06:37 PM
loudNproudSS
Apr 26, 2008 09:35 PM
