Engine Build: h-body l67 into w-body parts
Old Jan 25, 2014 | 11:15 PM
l67ss's Avatar
Default h-body l67 into w-body parts
Getting an l67 longblock from a park avenue. What w-specific parts do i need. U have w acc and sc brackets. I have a w oil filter adapter. I know i need lower eng mount and bracket.i kno i need driver side db bracket. Am i missing anything? Thanks
Old Jan 25, 2014 | 11:22 PM
04 SS/SC's Avatar
If your car is non supercharged your going to need tons. You buying parts new? Like injectors, pcm, fuel lines, etc...
Old Jan 25, 2014 | 11:28 PM
l67ss's Avatar
I have everything but the longblock
Old Jan 25, 2014 | 11:33 PM
04 SS/SC's Avatar
Well then you should be set everything bolts up the same it's same motor and same style of car. I believe my rebuilt motor from zzp was from a car like that or somethin idr
Old Jan 25, 2014 | 11:35 PM
04 SS/SC's Avatar
And honestly you should of put the l67 heads and intake in your n/a block it would be faster just not handle boost as well cuz of the high conpression
Old Jan 25, 2014 | 11:40 PM
l67ss's Avatar
Thats What i wanted to do but dont have the $ for that
Old Jan 28, 2014 | 07:57 AM
z34phoenix's Avatar
money for top swapping? are you talking cant afford the labor? or gaskets? i figured your doing this yourself.
Old Jan 28, 2014 | 03:25 PM
vikesfan's Avatar
you will need the W body passenger side upper motor mount bracket that incorporates the tensioner, ribbed idler pulley, and coil pack bracket.
Old Jan 28, 2014 | 04:23 PM
Hiroska's Avatar
He's always doing something new, lol. And more than likely doing it himself lmao.
Old Jan 29, 2014 | 08:02 PM
l67ss's Avatar
Yeah gaskets and bolts will set me back abou $400. I found a nearly perfect l67 with 85000 miles at a jy for $210, so the swap will cost about $300. I already have an l67 pcm that bumpin said woll work. I am gonna do a topswap eventually. Gonna do a serious build o it. Then ill sell the l67
