h-body l67 into w-body parts
Getting an l67 longblock from a park avenue. What w-specific parts do i need. U have w acc and sc brackets. I have a w oil filter adapter. I know i need lower eng mount and bracket.i kno i need driver side db bracket. Am i missing anything? Thanks :)
If your car is non supercharged your going to need tons. You buying parts new? Like injectors, pcm, fuel lines, etc...
I have everything but the longblock
Well then you should be set everything bolts up the same it's same motor and same style of car. I believe my rebuilt motor from zzp was from a car like that or somethin idr
And honestly you should of put the l67 heads and intake in your n/a block it would be faster just not handle boost as well cuz of the high conpression
Thats What i wanted to do but dont have the $ for that :(
money for top swapping? are you talking cant afford the labor? or gaskets? i figured your doing this yourself.
you will need the W body passenger side upper motor mount bracket that incorporates the tensioner, ribbed idler pulley, and coil pack bracket.
He's always doing something new, lol. And more than likely doing it himself lmao.
Yeah gaskets and bolts will set me back abou $400. I found a nearly perfect l67 with 85000 miles at a jy for $210, so the swap will cost about $300. I already have an l67 pcm that bumpin said woll work. I am gonna do a topswap eventually. Gonna do a serious build o it. Then ill sell the l67 :)
Originally Posted by z34phoenix
(Post 593522)
