Engine Build: gtp pcm
Old Jan 21, 2014 | 06:19 PM
l67ss's Avatar
Default gtp pcm
Ive heard several years of gtps pcms arent security locked. 98-99 right thanks
Old Jan 22, 2014 | 07:05 PM
l67ss's Avatar
No one knows?
Old Jan 22, 2014 | 07:15 PM
I'm not sure what you mean by "security locked". I know if you change to a different PCM, you typically have to do a PCM re-learn.
What are you looking to accomplish with a GTP PCM, perhaps that may help understand your question.
Old Jan 22, 2014 | 11:32 PM
l67ss's Avatar
I had just heard that 98-99 gp pcms were like gen 1 w pob2 pcms where you can just plug them in and go
Old Jan 23, 2014 | 06:21 AM
I have not heard the POB acronym....
It sounds like you are looking to avoid the security relearn with a PCM. If that's the case, the relearn is no big deal, you can do it yourself (I've done it on my Monte and my Grand Am when I used donor PCMs in them and a new tune updated with the correct VINs).
Not sure if you can make a PCM work if it doesn't have the correct VIN programmed in.
Old Jan 23, 2014 | 06:28 AM
l67ss's Avatar
Know on first gen ws the passkey is totally separate from the pcm. Not as in the know on 2nd gens tho. Are they passkey 2?
Old Jan 23, 2014 | 07:32 AM
Until 99 the key had a chip in it that spoke to the VATS system, instead of the passlock system, but I'm pretty sure no matter what the VIN needed to be programmed to the PCM and it wasn't just plug and play.
Old Jan 23, 2014 | 07:38 AM
l67ss's Avatar
On first gen ws as long as the pellet and pk module matched it worked, no vin involved
Old Jan 23, 2014 | 10:04 AM
Sadly, I don't have much knowledge of PassLock and the PCMs.
Old Jan 23, 2014 | 08:51 PM
I used a 98 gtp pcm for my swap. No issues with security.
