Engine Build: gtp pcm
I'm not sure what you mean by "security locked". I know if you change to a different PCM, you typically have to do a PCM re-learn.
What are you looking to accomplish with a GTP PCM, perhaps that may help understand your question.
I have not heard the POB acronym....
It sounds like you are looking to avoid the security relearn with a PCM. If that's the case, the relearn is no big deal, you can do it yourself (I've done it on my Monte and my Grand Am when I used donor PCMs in them and a new tune updated with the correct VINs).
Not sure if you can make a PCM work if it doesn't have the correct VIN programmed in.
Until 99 the key had a chip in it that spoke to the VATS system, instead of the passlock system, but I'm pretty sure no matter what the VIN needed to be programmed to the PCM and it wasn't just plug and play.
