gearshift won't come out of park
1995 MC. I think there's a solenoid somewhere that lets the shifter move after you press the shift button when the key is on and the brake is on. Since this is not happening ---- is the solenoid in the consol or where? How do I get to it to see if it gets power, moves etc? Thanks
I tried to get the top plastic cover around the gearshift off but it appears the gear position must be movable to get it off. I can see a solenoid on the motor side of the shifter and it does not move when key on and brake on but I think that may be the problem. I guess I'll have to break the top plastic cover to get it off. I'm leaving town tomorrow am for a week so I'll try it again then.
i had the same problem with mine. i just disconnected it from the shifter. the down fall is, when the key is on the brake does not have to be pressed to shift in to a different gear. i looked in to a new one and i have to buy the shifter with ever other item that is next to. it is not cheap.
4th Gen ('81-'88): Help gear shift button won't push can't get out of park
95mcarlodan
12-31-2014 02:00 PM
northerner
04-09-2013 10:34 PM
