6th Gen ('00-'05): gear set, 4th gear hub, channel plate gouged! help!
Old Apr 4, 2013 | 09:26 AM
turbo monte's Avatar
Default gear set, 4th gear hub, channel plate gouged! help!
OK so i tore my trans apart today and found one of my thrust washers was trashed between the gear and channel plate, my 4th gear hub was rubbing the chain gear. Both gears have some rash on them from this and the 4th gear hub has rash on it and also the channel plate. Any ideas on what caused this?!?! The chain and gear set was a 7/8th 2.93 ratio.....
channel plate
4th gear hub
drive gear (this is where the bushing was trashed)
driven gear
Old Apr 4, 2013 | 09:53 AM
You could always ask TEP, ask him for recommendations on the next build and just use the information
Old Apr 4, 2013 | 10:01 AM
i am planning on calling tep but he is closed till monday. just seeing if anyone else ever seen this happen and know why it happened....
2002 SS
Mar 10, 2014 09:21 AM
turbo monte
May 2, 2013 09:41 PM
matrx10503
Mar 12, 2012 08:31 PM
24_48Fan
Apr 19, 2008 07:48 PM
canuck
Mar 18, 2007 12:29 PM
