6th Gen ('00-'05): gear set, 4th gear hub, channel plate gouged! help!
OK so i tore my trans apart today and found one of my thrust washers was trashed between the gear and channel plate, my 4th gear hub was rubbing the chain gear. Both gears have some rash on them from this and the 4th gear hub has rash on it and also the channel plate. Any ideas on what caused this?!?! The chain and gear set was a 7/8th 2.93 ratio.....
channel plate
4th gear hub
drive gear (this is where the bushing was trashed)
driven gear
channel plate
4th gear hub
driven gear
i am planning on calling tep but he is closed till monday. just seeing if anyone else ever seen this happen and know why it happened....
6th Gen ('00-'05): trans build with a gmr 1" chain and gear set.
turbo monte
May 2, 2013 09:41 PM
matrx10503
Mar 12, 2012 08:31 PM
24_48Fan
Apr 19, 2008 07:48 PM
