Fwd ls4 swap into 02 SS
Old Apr 13, 2014 | 08:07 PM
garveySS's Avatar
Exclamation Fwd ls4 swap into 02 SS
I need some tips or suggestions on doing a ls4 swap
On my 02 monte carlo ss, i just need too know everything im going to need to make this swap possible, if any one can help me out that would be out standing thanks!
Old Apr 14, 2014 | 05:41 AM
Welcome to the forum. Good luck with doing this swap if you do do it.
Old Apr 14, 2014 | 12:04 PM
Moved this thread to a more appropriate section.
Old Apr 14, 2014 | 12:27 PM
dbaldwin's Avatar
There is a member who did it and I believe he did a partial write up. All wiring harness from the ls4 are required. As well as interior gauges, h vac, radio and all other electronics.
Old Apr 14, 2014 | 12:51 PM
It did require redoing all of the electronics due to the changes in PCM/BCM/etc
And the new gauges tied into a different system.
It was a TON of work, an L67 is truthfully the better option for a swap.
l67ss
Dec 30, 2013 10:16 AM
bama_z34
Nov 10, 2010 04:31 AM
scottwern184
34
Jun 4, 2010 06:20 PM
BLACK ATTACK
Oct 4, 2007 05:50 AM
rj
Jul 17, 2007 09:49 PM
