Fwd ls4 swap into 02 SS
I need some tips or suggestions on doing a ls4 swap
On my 02 monte carlo ss, i just need too know everything im going to need to make this swap possible, if any one can help me out that would be out standing thanks! |
Welcome to the forum. Good luck with doing this swap if you do do it.
Moved this thread to a more appropriate section.
There is a member who did it and I believe he did a partial write up. All wiring harness from the ls4 are required. As well as interior gauges, h vac, radio and all other electronics.
It did require redoing all of the electronics due to the changes in PCM/BCM/etc
And the new gauges tied into a different system. It was a TON of work, an L67 is truthfully the better option for a swap. |
