6th Gen ('00-'05): Fuel Pump Problem PLEASE HELP!
Old Feb 7, 2012 | 10:20 PM
StrongTakeover's Avatar
alright well today I had to work so i couldnt get much accomplished I bought some seafoam and put it in my fuel tank and to be honest it really didnt do much. Still running at a very uneven idle and sputters when I drove it home! I was suppose to visit home but I dont think thats going to happen since I dont have a dependable car right now. I fellow monte owner I customer at my job (Walmart tire&lube) said something about the fuel pressure regulator was going out on his do any of you all think replacing that might help?? Im trying to avoid taking it to a mechanic but i really dont know how to do much myself so im kind of in the slumps right now.
Old Feb 7, 2012 | 10:43 PM
It also will not start unless I press the gas also. If i just turn the key it stalls right out.
Old Feb 8, 2012 | 04:21 PM
boggie's Avatar
might not be fuel pump check fuel filter
Old Feb 8, 2012 | 05:10 PM
Saw this question and answer below....Plus I doubt you can drop your fuel tank from underneath without disconnecting the wires to the pump / sending unit from above. The pump is really easy to remove from above, versus draining your tank, removing the filler neck, support straps etc. You can go to a dealership and get a free estimate and diagnosis as to what they think the problem is. Just might save you replacing alot of unnecessary parts and save money in the long run.
Read more: I have a 2000 Grand Prix. The engine starts, but immediately stops. It will start and run if I press the gas pedal, but dies again when I let off the gas pedal. The problem has never been there before today. | Answerbag
The most likely problem is that you have a stuck/failed Idle Air Controller. This is a device that (as its name implies...;-D...) controls the air flow into the engine when you have your foot off of the accelerator pedal (which closes the throttle plate and chokes off air to the engine).
By pressing on the accelerator pedal, you are allowing some air into the engine which enables it to run. Once you take your foot off, the throttle closes and the engine starves for air.
Jomao_o's Avatar
Idle Air Control, or MAF sensors?
Old Feb 8, 2012 | 09:59 PM
WELL HOLY **** my car does exactly what the guy said his grand prix! Chibi said thats what he thinks it is too so I will be sure to tell the shop that in the morning this should be alot cheaper then a fuel pump! do you think this is something I can replace myself easy?
Old Feb 9, 2012 | 12:16 PM
ITS FINALLY FIXED! Mass air flow sensor replaced and shes never ran this good! he said my IAC valve was good so no sense in replacing it hopefully im all set
Old Nov 30, 2019 | 10:50 PM
BlackFall's Avatar
Default Fuel Pump to IAC
Fuel Pump was your first concern and you were wanting to drop the tank instead of accessing through trunk due to Sound System.
I did mine in an hour from inside my car through folding down the back seat. Lots of mats and fresh air... dirty job and gas fumes... but didn t have to remove the system , still had a foot of room behind the seat.
Drive Safe
lyskor
Sep 1, 2016 11:16 PM
fiveirontimmy
Mar 23, 2016 05:55 PM
bikerboyzzky
Oct 28, 2011 02:15 PM
DIGIMURDA
Mar 22, 2010 10:29 PM
ME Monte
Jun 2, 2009 08:02 PM
