Fuel line replacement?
To get out the crank bolt, takes some effort lol. You need to put a vise-grip on the flex plate so it cant move, then get off the crank bolt. Mine was on really good and I almost broke the old bar I was using. Heck the thing is torqued to 111 lbs and then about 70* Then you use the puller on the balancer.
I used some heat and my impact and the bolt came off. Then I used the puller and the thing popped off. Now I am just having trouble with the car running well. I got it started but its idling very weird.
x2
When I swapped the heads off of my Monte, it idled about 2k rpms. Found a vacuum line that wasn't hooked up right and then everything was fine.
ReaperSS
08-29-2014 11:35 AM
enigmatticus
02-28-2014 03:31 PM
