front exhaust manifold gasket?
Old Aug 13, 2013 | 12:53 PM
04IntimidatorSS's Avatar
Default front exhaust manifold gasket?
My powerlog is leaking go with a felpro gasket or get a metal one from the dealer? or does it really not make a difference?
Old Aug 13, 2013 | 03:57 PM
I personally don't think the gasket makes a difference. Is your leak from the actual gasket or a failing weld on the PLOG?
Old Aug 13, 2013 | 07:57 PM
nitehawkjcb's Avatar
I <3 my metal gasket fwiw
Old Aug 13, 2013 | 08:14 PM
Definitely check that PLOG, they are known to crack sometimes at the welds
Old Aug 14, 2013 | 11:16 AM
turbo monte's Avatar
I agree check the plog very good there has been many cases people had them crack.... if the plog is fine I say go with a metal gasket every time!
Old Aug 14, 2013 | 02:15 PM
the plog is fine had the welds redone by my buddy who is a wlder but when we installed it a while back my cousin stripped 2 bolts near the pulleys so I can feel so exhaust leaking out so now I have to take it off and trying fixing the stripped holes and get a new gasket
Old Aug 14, 2013 | 05:57 PM
If its a metal gasket on there and its not all bent etc you can clean it spray it with the copper spray gasket stuff and reuse it. I've always reused them.
Shandley
FWD Tech Guides '95-'07
Oct 21, 2019 09:02 PM
gamber03
Jul 10, 2008 12:06 PM
monteriderLS
Nov 11, 2006 10:26 AM
agentk006
Jan 6, 2006 04:37 PM
bumpin_monte01
Aug 28, 2005 06:05 PM
