Engine Whine
Old Jun 26, 2011 | 10:55 PM
clucia01's Avatar
Default Engine Whine
lately my car has been making a whining noise almost like a supercharger would make but i can obviously tell that my car is not supercharged. the sound stopped for the most part over the winter but now that its summer its started doing it again. i cant tell if its the engine or the transmission. can anyone shed some light on this situation as to what it might be?
Old Jun 26, 2011 | 10:58 PM
Enzo354's Avatar
STILL SLOW
Power steering pump im sure.
Old Jun 26, 2011 | 11:59 PM
Budsjlm's Avatar
x2 i'd start by checking your power steering fluid
Old Jun 27, 2011 | 12:08 AM
alp312's Avatar
x3 on the power steering replaced mine
Old Jun 27, 2011 | 06:28 AM
monte07's Avatar
first i will check the belt some times you will get a whine from that as well some times a squeel but i will go with that first. second check the level of the power steering fluid if it is fine and still makes the sound it is the pump. the reson why i said check the belt and fluid level it is the cheapest thing to do first then. you will know it is the pump the power steering pump is much more than a belt and fluid for it. i agree the sound that you are hearing is from the pump but i was just saying from imo to check the other two first to try to save a little money
sixscarlo
Mar 4, 2012 10:11 PM
07MonteMadness
Mar 23, 2011 09:01 AM
saigashooter
Oct 21, 2009 08:28 AM
Coors
Mar 5, 2009 09:03 PM
kweef
Jan 6, 2009 11:35 AM
