Engine Temps
Okay so ive tried everything! Im 100% confident that there are no air pockets in the system. The car consistently runs between 210-220 while driving. (fans always on chibi) As soon as i park and let it run for 3-4-5 min the temp is back down to 195 ish.
Every time i pull the rad cap off to check the level, i need to add like 8 ounces... I have no leaks that i can find. everything id dry under the car. I dont see the overflow bottle getting fuller. Where is the coolant going? I replaced the head gaskets 200 miles ago so i would hope the air isnt passing into the cooling sys from the cylinders...
Im at a loss... help?
This is what my scan gauge calls 217 degrees. look about right? (pic)
Well, I guess ill have to do a pressure test tomorrow. *fingers crosses* I just rebuilt the engine so i hope its not the head/lim gaskets. sigh
I have an aeroforce scan gauge, but i dont think i can change the fan "on" temp. Do i need a special tool/scanner or do i just need to find a tuning shop to change the 'on temp'?
Any other thoughts?
Thanks guys. i really appreciate it.
Any other thoughts?
Knightwolf702
05-14-2014 07:13 PM
z34phoenix
01-04-2012 04:05 PM
matrx10503
10-26-2010 09:59 AM
