Engine Problem?
Old Aug 7, 2012 | 11:56 PM
2005ssmonte's Avatar
Default Engine Problem?
weird problem between 30-80mph my engine will start missing I have no CEL, however I did just get my transmission rebuilt I took it back to get reassured my tranny wasnt bad and it turns out to be a engine miss rather than a slip... what could it be
Old Aug 8, 2012 | 02:52 AM
blueSS's Avatar
Need more info It could be any number of things.
What engine is your car?
How many miles?
Whens the last time your did a tune up?
Have you checked your spark plugs?
Old Aug 8, 2012 | 06:05 AM
Without more info (as stated above) could be any list of things:
- Bad plugs/wires
- A wire arcing
- Failing Coil (not common, but has happened)
- Bad injector
- Failing fuel regulator
- Failing fuel pump
- Failing CAT
If you have access to a scan tool that can give some sensor reads and such, those ones can typically read cylinder mis-fire data. It may tell you which cylinders are mis-firing (even without a code). That can help pin point the issue (if it's one or two cylinders, limits the issue).
Old Aug 8, 2012 | 06:25 AM
zipper's Avatar
According to his username, he's got an L67. Regardless OP, check out what has been mentioned above and let us know what you found.
Old Aug 8, 2012 | 07:38 AM
03SSLE's Avatar
When is the last time the fuel and air filter were replaced and the MAF sensor cleaned? Those could cause the engine to hesitate (which wouldn't set a code) but if the engine was actually misfiring a code would be set after two occurrences.
Old Aug 8, 2012 | 09:15 PM
It only does it when the engine temp reaches around 180-190 and it doesnt help that the texas heat is around 110 right now... I'm leaning towards a overheating coil?
When i bought the car used the dealer changed all the plugs and wires
Old Aug 8, 2012 | 09:16 PM
I cleaned the MAF sensor when i got bank 1 too lean and that solved the CEL i got that awhile back before this started happening
Old Aug 9, 2012 | 07:24 PM
SS02's Avatar
have that cat checked, that is kinda what mine was doing.....thought I had a fuel or spark miss with no codes.....but it was a clogged cat
Old Aug 11, 2012 | 08:41 PM
Update*
After driving for awhile no missing or weird shifting at all after cleaning my MAF sensor again the light came on for a p0741 tcc stuck off... should i take it back or should i see if its just due to the break in period i havent been hotroddin... i had my tranny rebuild in the last car and this code came on after driving a long way but after about 2000 miles the code never came on again
Knightwolf702
May 14, 2014 07:13 PM
Justin Myers
Sep 19, 2012 08:23 PM
inyanalili
Apr 2, 2012 08:31 AM
The Black Machine 29
Jun 1, 2006 11:49 PM
brvancamp
Dec 13, 2004 11:35 AM
