Engine Oil weight? Because of??
Old Jul 6, 2008 | 07:35 PM
zipsayain's Avatar
Default Engine Oil weight? Because of??
Should you change the weight of your oil, Just because of high miles?
Old Jul 6, 2008 | 09:05 PM
Cowboy6622's Avatar
Default RE: Engine Oil weight? Because of??
that depends.there is wear on the piston rings, a little on the pistons themselves, and the cylinder wall. a thinner oil can slip thru and end up in your fuel mixture. i would increase the weight if you're car is burning a little oil. if the car hasn't burned a drop in however many miles your running between changes, i wouldn't worry about it. if the car starts to burn a half quart-quart every few thousand, i'd move the weight up to about 10W 40 or so.
hope this is helps
LennyLeonard
Nov 15, 2016 06:02 PM
Budsjlm
Aug 17, 2012 04:50 PM
SickParadox
Apr 18, 2011 01:17 PM
zipsayain
Mar 15, 2007 10:43 PM
zipsayain
Apr 26, 2006 12:03 AM
