6th Gen ('00-'05): Engine oil pan removal
Old Mar 26, 2013 | 10:05 PM
Rod in MN's Avatar
Default Engine oil pan removal
HI, Guy's I havea 2001 Monte Carlo with a oil leak under the engine. Going to try the oil pressure sender first. Can the pan come out with takeing the engine out or takeing it loose. I also have oil setting in the motor mount under damper do the front crank seals leak or would it be the timingcover. Oil is covered the RH side under the car and drips off the engine cradle.
The top intakeis also leaking would it be best to replace both upper and lower intake gasket. How hard is it to replace the intake gasket any idles on short cuts
Thank You
Rod in MN
Old Mar 26, 2013 | 10:56 PM
turbo monte's Avatar
If the intake baskets are leaking I suggest fixing them asap. The crank seal could be leaking but if it was leaking there would be oil getting on the belt and then flung onto the hood etc. I am willing to bet its the oil pan gasket. If this is a 3800 engine you either have to lift the engine up a bit and unbolt the engine mount from the engine or you have to drop the engine cradle to gain room to remove the oil pan. Oil pans suck to do lol.
Old Mar 27, 2013 | 01:27 PM
Rod in MN's Avatar
Thank's dose not sound like a ease job to do. It's the son's car i used it yesterday had the sun roof open and could smell oil on the manifold or exhaust. Why would there be oil sitting in front motor mount crank seal or timing cover. Will the motor have to be pulled to replace timimng cover gasket??
Thank You
Rod in MN
Old Mar 27, 2013 | 05:14 PM
owens91's Avatar
i actually had mines done at a local shop, cost 300 cause there was always oil under the car. i watched them take the pan off and i bust a sweat just watching them. but once they did there wasnt even a gasket on.... glad the monte not constantly bleeding now lol
Tzarm
Aug 20, 2012 09:20 AM
crete
Nov 6, 2011 07:05 PM
shanefer
Apr 21, 2009 04:12 PM
koreancore
Jan 14, 2009 04:59 PM
black2001montess
Aug 27, 2007 04:45 PM
