Engine question
Old Mar 28, 2013 | 10:18 AM
mairj40's Avatar
Default Engine question
I need some input from the 5th gen guys. I am looking at a 96 Monte with a 3.1. The guy says it has lifter knock. I'm thinking that, if I get it, I'd just swap out the whole engine to be sure that it is good to go. Could I swap in a 3400 without too much trouble? Or even a 3800? I'm thinking that the engine computers would be completely different.
Old Mar 28, 2013 | 10:23 AM
You would just need all of the parts, engine, trans, wiring harness, computer from the donor.
3.1 lifter tick is common on cold starts.
Old Mar 28, 2013 | 10:37 AM
mairj40's Avatar
Thanks Chibi. It has been awhile since I had a 3.1. Probably 15 years or better. The car has 207,000 on it, so I'm leaning towards a complete engine replacement (if I get the car) He only wants $600 for it, and the body is in decent shape. Just a couple small rust spots. I haven't crawled under it yet though, so the undercarriage could be shot.
Old Mar 28, 2013 | 11:14 AM
Could be worth just looking for a 98-99 z34 instead
Old Mar 28, 2013 | 11:19 AM
nitehawkjcb's Avatar
You can swap a 3400 with no modification I believe, a 3800 though is a totally different story. You need the PCM, wiring harness, transmission, axles at least.
Old Mar 28, 2013 | 11:37 AM
Since the 3400 and 3100 use the same block, from what I've read the swap is pretty much straight forward. The mid-90's Grand Am guys have done that swap a few times. THere are soem write ups about it (as there can be a couple small issues, and I mean SMALL that it helps to see what othrs have done before).
Knightwolf702
May 14, 2014 07:13 PM
z34phoenix
Jan 4, 2012 04:05 PM
matrx10503
Oct 26, 2010 09:59 AM
RickCoMatic
Jan 5, 2008 06:30 PM
locs
Jun 8, 2006 05:09 PM
