Dyno tune
I just talked to a guy who does dyno tunes and he said I would probably only get about 10 horse and it would cost 350? I thought it would give me more than that. I have a 07 ss with. K&N and exhaust. Does this sound right or is he off a little? Thanks
It's quite possible that you would only gain about 10whp. Doing a dyno tune should be done after you get a lot of work done, maybe after you do headers or something big. An intake and exhaust is hardly anything. But also keep in mind that a tune can raise more then just peak hp. It can also raise hp all across the power band. So if you made 10whp more from 3000-5500rpm, then it would be worth it.
But if you're looking for bragging rights, then it wouldn't be worth it.
If that's all you want, there are cheaper options.
You can also look at doing a diablew tune, and at least you'll own the little handheld tuner for the same price.
Where are you located? If local, I can also help with just that minor stuff for nice and cheap.
That's not really true at all.
I would go with Overkill personally, but I have seen great things with Diablew tunes as well.
