Dyno tune
Old Aug 20, 2014 | 05:11 PM
bigjon30's Avatar
Default Dyno tune
I just talked to a guy who does dyno tunes and he said I would probably only get about 10 horse and it would cost 350? I thought it would give me more than that. I have a 07 ss with. K&N and exhaust. Does this sound right or is he off a little? Thanks
Old Aug 20, 2014 | 05:16 PM
gasman's Avatar
Price is to high and 10 hp is hardly worth it or even noticeable
Old Aug 20, 2014 | 05:17 PM
gasman's Avatar
For some reason those side ways LS engines get no love
Old Aug 20, 2014 | 08:22 PM
zipper's Avatar
It's quite possible that you would only gain about 10whp. Doing a dyno tune should be done after you get a lot of work done, maybe after you do headers or something big. An intake and exhaust is hardly anything. But also keep in mind that a tune can raise more then just peak hp. It can also raise hp all across the power band. So if you made 10whp more from 3000-5500rpm, then it would be worth it.
But if you're looking for bragging rights, then it wouldn't be worth it.
Old Aug 20, 2014 | 09:42 PM
turbo monte's Avatar
Zipper is correct.
Old Aug 20, 2014 | 11:29 PM
bigjon30's Avatar
I'm not looking for bragging rights. I mainly want to get the dod disabled and to firm up the shifting. Would I be better off going with will at overkill or what do you guys think?
Old Aug 21, 2014 | 08:58 AM
If that's all you want, there are cheaper options.
You can also look at doing a diablew tune, and at least you'll own the little handheld tuner for the same price.
Where are you located? If local, I can also help with just that minor stuff for nice and cheap.
Old Aug 21, 2014 | 09:19 AM
That's not really true at all.
I would go with Overkill personally, but I have seen great things with Diablew tunes as well.
Old Aug 21, 2014 | 10:33 AM
gasman's Avatar
[QUOTE=red04montels;627421]That's not really true at all.
Yes it is.. Nobody ever says " wow do u feel that 10hp difference" lol
Old Aug 21, 2014 | 11:15 AM
xxtheshockerxx's Avatar
RED DEVIL
I have an overkill tune and made 293 at the wheels with his canned tune. It works great for what it is.
