do I need a gtp fuel pump for the the sc motor swap
Old Mar 5, 2014 | 07:17 PM
duster413's Avatar
Default do I need a gtp fuel pump for the the sc motor swap
I did a full motor swap in my wife's 02 Monte with a 99 gtp motor. After the swap it ran without the computer bein tuned but it would idle from 600 rpm to 1200 rpm. But it would start and run. I sent the computer to a guy in Canada to get tuned for the swap. When I got it back the car won't start unless I prime it, the car runs great after that but won't start up again without being primed. Now I can't get ahold of the guy that tuned it. I'm running 42 pounds of fuel pressure key on engine off when it requires 48 minimum. Do I need a gtp fuel pump or will a new Monte pump work?
Old Mar 5, 2014 | 08:06 PM
l67ss's Avatar
New monte pump will work. Who did the tune?
Old Mar 6, 2014 | 02:57 PM
duster413's Avatar
Awesome,thanks. I believe it was lt1 pcm tuning. It was awhile back and I still haven't figured out my starting issue. I have the box at work and can confirm the tuner later.
Old Mar 6, 2014 | 03:09 PM
l67ss's Avatar
Check cranking psi, its possible the pump just isnt kicking on
Old Mar 6, 2014 | 03:42 PM
duster413's Avatar
Cranking psi went up to around 46 if memory serves!
Old Mar 6, 2014 | 03:50 PM
duster413's Avatar
I'm running everything from the Monte except the motor. The wiring harness is from the Monte.
Old Mar 11, 2014 | 09:42 AM
duster413's Avatar
The guy that did my tune was from overkill motorsports in Toronto.
Old Mar 11, 2014 | 05:58 PM
A05C's Avatar
I have a stock pump in mine. Mine is an L36 car also.
Stock pump, stock L67 injectors. It starts to lean out when it gets really cold, but its not too bad.
Old Mar 12, 2014 | 07:42 AM
duster413's Avatar
Did you run the l36 harness? The one time overkill did contact me back he stated that he programed the ecm for a gtp harness.
Old Mar 12, 2014 | 07:51 AM
l67ss's Avatar
The only dif between gtp harness and monte harness is bbv solenoid. When guys first started l67 swapping 95-99 montes they used 97-98 gtp pcms...on a motes harness. Id try a dif tune
