do I need a gtp fuel pump for the the sc motor swap
Old Mar 13, 2014 | 07:41 AM
duster413's Avatar
If this new pump don't fix it then that's what I'll be doing. Overkill said I had to trick a sensor since it was supposedly tuned for a gtp. So I have been basically chasing ghost all this time. Does anyone know who does a good affordable tune? Thanks everyone who has taken time to help me address this issue!
Old Mar 13, 2014 | 08:22 AM
l67ss's Avatar
Theres a guy on fb that tunes for like $75
Old Mar 13, 2014 | 08:56 AM
z34phoenix's Avatar
overkill does the best tunes hands down if your having issues with it, either it is the pump, or it was an honest mistake. give him a chance to correct it. what year monte do you have? i have a 98 harness and drivetrain in my Z and am running 98 L36 code in the pcm. i recently tried a modified 99 GTP file and had some issues with it. i would suggest asking will at overkill to build the tune off your existing NA file.
Old Mar 13, 2014 | 08:57 AM
z34phoenix's Avatar
oh nvm. 02 mc with 99 gtp engine.... that idle makes me think you have a vac leak...
Old Mar 13, 2014 | 12:49 PM
l67ss's Avatar
What issue you have with 99 gtp bin pheonix?
Old Mar 13, 2014 | 07:53 PM
z34phoenix's Avatar
there must be harness differences between the 99 gtp and 98/99Z34. with the 99 GTP bin file and pcm i had 5 codes in addition to a case learn code. even after removing them from the bin file they still would show up. having active codes prevent the completion of a case learn. Without a case learn rpm will not be accurate and timing and fuel will be incorrect.
Old Mar 13, 2014 | 11:12 PM
l67ss's Avatar
Im running a 99 gtp pcm. Only codes that popped up is gear ratio qnd wastegate(bbvsolenoid)
Old Mar 14, 2014 | 06:31 AM
duster413's Avatar
I've tried and tried to contact him at overkill. He told me he made a mistake when he tuned it to go in a gtp. Don't see how that's a mistake. He would not answer anymore emails after I asked him to stand by his product.
Old Mar 14, 2014 | 07:34 AM
Not to make excuses for Will, but he is a full-time accountant and this is probably the busiest time of the year for him
Old Mar 14, 2014 | 02:25 PM
z34phoenix's Avatar
Like said he is a good guy. Just like Holmes on homes. "He will make it right".
As fr the PCM. L67ss what harness are you running? Are your egr and evap hooked up? The 99 gtp PCM runs the car but without beig able to run a case learn I don't feel safe with it. So now it is just a backup limp home PCM if I ever need it.
