do I need a gtp fuel pump for the the sc motor swap
I did a full motor swap in my wife's 02 Monte with a 99 gtp motor. After the swap it ran without the computer bein tuned but it would idle from 600 rpm to 1200 rpm. But it would start and run. I sent the computer to a guy in Canada to get tuned for the swap. When I got it back the car won't start unless I prime it, the car runs great after that but won't start up again without being primed. Now I can't get ahold of the guy that tuned it. I'm running 42 pounds of fuel pressure key on engine off when it requires 48 minimum. Do I need a gtp fuel pump or will a new Monte pump work?
