Distributor Cap Popping Off(1st Thread)
Old Sep 3, 2010 | 01:15 AM
mhallen13's Avatar
Red face Distributor Cap Popping Off(1st Thread)
Hi my name is Matt, I am new to the forum and this is my first Monte Carlo.
I have a 75 Monte Carlo with a GM 350 with supposedly ~18000 miles.
and on to the original reason for posting my first thread:
A part of the rack and pinon(speaking from listening not working on first hand) in the ignition system had broke causing the key & tumbler to spin but not start.. At the time the most efficient solution was bringing it to a shop(expensive I know but w/e). 3 days later cars fixed and starts. Pulling out of the neighboor morning of picking up the car I punch the gas to join traffic(nothing extreme but still some power). I hear a malfunction noise, a clicking starts.
Turns out it was the distributor cap and after popping it back into place the click is gone. Correct my terminology but the rotor was hitting the inside of the cap to make the click noise.
Twice more when giving the car more gas than normal from a stopped position the cap has "moved" or "popped" positions and started to click.
This was all today and I have not examined anything in daylight nor try to replace the cap or any of it's securing hardware, so I was hoping for some leads or advice, thanks?
Old Sep 3, 2010 | 02:47 AM
Could be a bad motor mount. Motor moves under acceleration causing the cap to hit the firewall and popping it off. That gives you someplace to start i guess
Old Sep 3, 2010 | 06:32 AM
monte07's Avatar
i had the same problem with my cougar it is the motor mounts when the engine twists the fire wall and the hood. so it is the motor mounts they dont last forever but when they wier out it causes problems for every thing else.
Old Sep 3, 2010 | 10:32 AM
Budsjlm's Avatar
befor you go jumping into motor mounts check the cap make sure it is secured down
Old Sep 3, 2010 | 06:49 PM
mhallen13's Avatar
The cap is secured, but it does allways come undone at the same point. I am going to look at with my Father and I will update.
Old Sep 5, 2010 | 04:04 PM
mhallen13's Avatar
Well those who guessed it was the motor mount were correct. Although the motor mount itself is not bad, the auto shop didn't put the bolt back in! LOL Thanks for your help!
Old Sep 11, 2010 | 10:26 AM
mhallen13's Avatar
My Father and I bought the replacement bolt but could not get it trough the second half of the mount(engine side). We could not figure out where to jack the engine to basically move it towards the passenger side and line up the hole. Any ideas?
Old Sep 12, 2010 | 03:26 AM
Glad we could help. I'd just put a piece of wood between the jack and the oil pan so you dont dent it. That should move it enough to get the bolt in. If you have a cherry piker or a chain fall you could lift it from the top. Good luck
montecowlo
Dec 1, 2014 10:23 AM
Visceron
Jun 19, 2010 06:01 AM
Jcb
Mar 12, 2010 08:09 AM
mickey
Aug 26, 2005 03:25 AM
Cobramen
May 25, 2005 01:06 PM
