6th Gen ('00-'05): Disappearing oil
2002 SS with 116,000 miles. I noticed that my car seems to need a quart of oil every 3,000 miles. It never drips on the ground and I don't think it is using it. I noticed at the bottom of the engine on the passenger side that there is like a rubber looking thing and it looks like some oil may be laying in it. I wish I could explain what I mean better. It's kind of under the belt. It's hard to see without shining a flashlight down there. But if it was leaking a quart every 3,000 wouldn't it drip on the ground? Any ideas would be greatly appreciated! Thanks!!
I assume you are running conventional motor oil? There is a certain amount of oil "consumed" with every mile driven. A quart in 3000 miles does seem a bit on the high side to me.
The area you describe is suggesting a possible leak at the oil pressure sending unit. If I recall, it's located roughly under the power steering pump, accessed by removing the front passenger side tire and possibly the inner fender skirt. If that is the leak, I believe it's fairly easy and cheap to replace. Sometimes you can catch the leak by removing the wire from it, start the car and carefully looking in the connector of the sending unit (may require a mirror) and you may catch oil seeping through. Or if the you see signs of oil on the connecting wire and connector, that too may assist in proving that to be the issue.
These units can fail anywhere between 100,000-150,000 miles.
MAX MINJAREZ
Jan 28, 2012 10:05 AM
