Cylinder one misfire
Old Apr 4, 2013 | 11:10 AM
BrandonStebing's Avatar
Default Cylinder one misfire
2000 monte ss, check engine light on, code says cylinder one misfire. I've replaced the plugs, wire, and coils. Before replacing this, the motor was burning some oil, just did an oil change, so I figured I spilled some. But after replacing the plugs, and other things I noticed that it would smoke. Popped the hood and its coming from the first spark plug on the left, plug 3 I believe. My light is still on, and you can here the misfire. At a dead end, not sure what to do now.
Old Apr 4, 2013 | 11:21 AM
What did you replace with? If it was Bosch, that could still be the issue.
If not, suspect fueling as the issue too. Maybe the injector is stuck
Old Apr 4, 2013 | 11:24 AM
You are getting smoke from the first spark plug???
My guess it that you have either you are burning oil spilled on/around plug 1, a bad plug, a mis-threaded plug or a cracked head (assuming I understand correct and you are getting smoke from the plug).
If the plugs you used are BOSCH, rip-em out. BOSCH plugs have high failure and sometimes no luck after install (another words problems after install). Stick with AC Delco or NGK.
Normal causes of a specific cylinder mis-firing are:
- Vacuum leak
- Plug
- Wire
- Injector
- Coil
Old Apr 5, 2013 | 08:10 AM
- Vacuum leak
- Plug
- Wire
- Injector
- Coil
i put in AC Delco plugs and, duralast wires. ill check the plug and see if it was in right. but as for checking to see if the injector is stuck? thanks for your help this website, is the best place to go to find out whats going on with you MC.
Old Apr 5, 2013 | 11:39 AM
I've heard of a method to get an ohm reading from each injector and find one that is really different (not totally accurate)
Any time I suspected an injector, I've had a guy I know who has access to a GM Tech II scan tool check things out. On most (if not all) modern GM cars, the GM Tech II allows him to turn off one injector at a time to find the one that makes the least change in engine performance and they tells you which one is the bad one.
Old Apr 6, 2013 | 03:02 PM
I'll try that. Thanks for you help, you reply to almost all my post and you know what you're talking about
BrandonStebing
Mar 30, 2013 08:22 PM
05montecarloyo
Aug 8, 2012 07:02 PM
menaja19
14
Jan 2, 2008 09:21 PM
mloiselle20
May 1, 2007 04:58 PM
