Cylinder 6 misfire code
I just finished installing new lower intake manifold gaskets and put the engine back together. I installed new spark plugs at the same time and it is running very sluggish now and coded with a cylinder 6 misfire. I pulled the #6 plug and it is covered with gasoline. Any suggestions?
![Confused](https://montecarloforum.com/forum/images/smilies/confused.gif)
Thanks for the reply ChibiBlackSheep. I've put new lower o-rings on each of the injectors and it still codes as a cylinder 6 misfire. In all, I have replaced pcv valve, fuel filter, sparkplugs, wires, and lower o-rings on injectors. I've also put injector cleaner in with full gas tank. Any other suggestions
I didn't replace the upper 0-rings where the injectors go into the fuel rail, because I haven't removed the fuel injectors from the fuel rail, and thus figured that I couldn't have done any damage to the upper 0-rings. The plugs I bought were midrange in price (I can't remember the brand) and wires that I bought were standard but lifetime warranty ones from O'reily.
The plugs I have are Denso. I swapped the #6 cylinder spark plug with the #4 cyllinder spark plug and it still is coding as a #6 cylinder misfire. When I pulled the new spark plug from the #6 cylinder, it was covered in gas just like the old one. Put a new coil on for the #6 cylinder, per advise from a guy at the auto store, but it still acts the same. What should I try next
