Cylinder 6 misfire code
Old Sep 11, 2012 | 11:27 AM
Jayhawkbrown's Avatar
Default Cylinder 6 misfire code
I just finished installing new lower intake manifold gaskets and put the engine back together. I installed new spark plugs at the same time and it is running very sluggish now and coded with a cylinder 6 misfire. I pulled the #6 plug and it is covered with gasoline. Any suggestions?
Old Sep 11, 2012 | 11:51 AM
Check the injectors, you probably tore an o-ring
Old Sep 17, 2012 | 02:38 PM
Thanks for the reply ChibiBlackSheep. I've put new lower o-rings on each of the injectors and it still codes as a cylinder 6 misfire. In all, I have replaced pcv valve, fuel filter, sparkplugs, wires, and lower o-rings on injectors. I've also put injector cleaner in with full gas tank. Any other suggestions
Old Sep 17, 2012 | 02:58 PM
There are 2 o-rings per injector, are you sure one isn't torn?
Also what wires/plugs did you use?
Old Sep 17, 2012 | 03:06 PM
I didn't replace the upper 0-rings where the injectors go into the fuel rail, because I haven't removed the fuel injectors from the fuel rail, and thus figured that I couldn't have done any damage to the upper 0-rings. The plugs I bought were midrange in price (I can't remember the brand) and wires that I bought were standard but lifetime warranty ones from O'reily.
Old Sep 17, 2012 | 03:17 PM
I ask because our cars dislike Bosch, and some other non-AC Delco plugs and wires.
If you move plugs around does it stay on cylinder 6?
Old Sep 17, 2012 | 03:29 PM
I haven't moved any plugs around yet.
Old Sep 17, 2012 | 03:45 PM
Could it be as simple as a bad spark plug?
Old Sep 17, 2012 | 03:48 PM
It can. Especially if it is a Bosch plug
Old Sep 18, 2012 | 10:59 AM
The plugs I have are Denso. I swapped the #6 cylinder spark plug with the #4 cyllinder spark plug and it still is coding as a #6 cylinder misfire. When I pulled the new spark plug from the #6 cylinder, it was covered in gas just like the old one. Put a new coil on for the #6 cylinder, per advise from a guy at the auto store, but it still acts the same. What should I try next
