Crankshaft Positioning Sensor - 97 Monte
Hey all,
My 97 Monte Carlo is throwing a code that the crankshaft positioing sensor needs replaced. From what I've been told, replacing it is a matter of sliding the old one out and a new one in. However, I don't know where the sensor is or how much work it will take to get to it. If anyone here could help me out with instructions of how to get to it (or if I'm better off just taking it to a shop) I'd really appreciate it.
Thanks,
Rob
Thanks,
Rob
Instructions for the 3.8 are as follows - 3.1 is similar but appears that there is no crankshaft pos sensor shield. Disconnect neg bat cable. remove serp belt from crankshaft pulley. raise vehic. remove RF wheel/tire. remove rf inner fender access cover. remove crankshaft harmonic balancer. remove crankshaft position sensor shield. disconncect sensor conector. remove attaching bolts from sensor. remove sensor. install would be the reverse.
![Thumbsup](https://montecarloforum.com/forum/images/smilies/thumbsup.gif)
Hey all,
Thanks,
Rob
Thanks,
Rob
There are 2 crank sensors. one behind the harmonic balancer (24X sensor) and one on the firewall side of the engine block (7X sensor). you will need a professional scanner to read the data to determine which sensor you need. are there any driveability issues or does it run fine except for setting the code? what is the code? P0???
Hope this helps.
Hope this helps.
philly94ss
22
11-07-2011 02:27 PM
hendrick03
07-13-2011 09:31 AM
erik2282
04-27-2009 04:32 PM
motivation2k3
09-04-2008 07:15 AM
