Crankshaft Positioning Sensor - 97 Monte
Old Jan 24, 2010 | 11:32 AM
robwofter's Avatar
Default Crankshaft Positioning Sensor - 97 Monte
Hey all,
My 97 Monte Carlo is throwing a code that the crankshaft positioing sensor needs replaced. From what I've been told, replacing it is a matter of sliding the old one out and a new one in. However, I don't know where the sensor is or how much work it will take to get to it. If anyone here could help me out with instructions of how to get to it (or if I'm better off just taking it to a shop) I'd really appreciate it.
Thanks,
Rob
Old Jan 24, 2010 | 03:08 PM
JaxJim's Avatar
Instructions for the 3.8 are as follows - 3.1 is similar but appears that there is no crankshaft pos sensor shield. Disconnect neg bat cable. remove serp belt from crankshaft pulley. raise vehic. remove RF wheel/tire. remove rf inner fender access cover. remove crankshaft harmonic balancer. remove crankshaft position sensor shield. disconncect sensor conector. remove attaching bolts from sensor. remove sensor. install would be the reverse.
Old Aug 6, 2011 | 03:07 AM
oliver's Avatar
this is one informative post. is this exclusive for the 3.8? I hope you can post more instructional stuff like crank position sensor replacement in the future
Old Aug 9, 2011 | 12:21 AM
oliver's Avatar
Originally Posted by robwofter
Hey all,
Thanks,
Rob
I have a faulty crank position sensor. I don't know where to get a replacement part. Can you possibly recommend a website or a local store? thanks
Old Aug 9, 2011 | 08:34 AM
Enzo354's Avatar
STILL SLOW
I would suggest breaking the bolt loose before you jack up the car, they arent too fun. just remember you will need a new bolt too.
Old Aug 10, 2011 | 10:33 PM
mi88mcss's Avatar
There are 2 crank sensors. one behind the harmonic balancer (24X sensor) and one on the firewall side of the engine block (7X sensor). you will need a professional scanner to read the data to determine which sensor you need. are there any driveability issues or does it run fine except for setting the code? what is the code? P0???
Hope this helps.
Slow_SS
Oct 29, 2012 02:47 PM
philly94ss
22
Nov 7, 2011 02:27 PM
hendrick03
Jul 13, 2011 09:31 AM
erik2282
Apr 27, 2009 04:32 PM
motivation2k3
Sep 4, 2008 07:15 AM
