6th Gen ('00-'05): code p0108
Old Nov 9, 2013 | 05:02 PM
owens91's Avatar
Default code p0108
ugh so heres the deal, i fixed the fuel regulator problem but not heres the next i have thrown a p0108 code,which according to my scanner i am getting a high volt reading from my MAP sensor. i unplugged it with the car in the on position and it read no volts. but when i plugged it in it read around 0.85. with the engine starts running the scanner reads 0.20-.50 but sometimes go up to .80. im thinking about ordering another one. but should i take anymore steps to diagnose this?
Old Nov 9, 2013 | 06:21 PM
JC Colon's Avatar
I would get a new MAP. But I recommend that you get a new PCV Valve at the same time. Your PCV is located under the MAP and they work together. I found out the hard way to replace the PCV BEFORE OR WITH THE MAP. I replaced my MAP twice in 6 weeks. The first time just the MAP. The second time, the PCV and MAP together. That took care of the code!
Old Nov 10, 2013 | 10:40 AM
owens91's Avatar
Upon further inspection I wiggled the wire harness and the numbers jumped with it. I ziptied the wires and the numbers seemed to stabilize. But still was above 0.50 (0.65) So I still might order a new map sensor but I'm starting to believe its the wire. The pcv valve is new came with the dorman kit. And now another code showed uo, p0101 something to do with the maf sensor, so I cleaned it and out it back hopefully thats it we shall see
Old Nov 11, 2013 | 08:13 AM
owens91's Avatar
Well this morning I was driving and car sputtered all crazy then died. After numerous tries I got it to start and went to work. The p0101 code came back up. So I cleaned it again. I'm gettin a map sensor today but is there a certain type of maf sensor to get? I'm starting to get real irritated with this car
Old Nov 11, 2013 | 09:00 AM
JC Colon's Avatar
AC/Delco! The aftermarket ones don't work very well with others!
Old Nov 11, 2013 | 11:08 AM
owens91's Avatar
What about a cardone maf? Thats all autozone got. And I wanna get this fixed asap so I'm iffy about ordering it
yfz450man
Jul 24, 2011 02:21 AM
mdfan
Dec 23, 2010 02:10 AM
cj702
Aug 28, 2005 12:50 PM
chorales
Jul 24, 2005 05:33 PM
king2805
Jul 14, 2005 10:34 AM
