Change or don't change tranny fluid at 87k?
Old Mar 24, 2012 | 08:38 PM
dcnaser's Avatar
Default Change or don't change tranny fluid at 87k?
Bought a 2004 SS with 87k. Fluid looks dark. Shifting is perfect with no issues. Will it be risky to change it now? Should I tell express oil to replace the filter and flush it or just drain and fill?
Old Mar 24, 2012 | 08:40 PM
MAMONTE's Avatar
Absolutely one of the first thingsI did was a fluid overhaul. Drop the pan, change the tranny fluid and filter, refill with Dexron VI.
I would also do an oil and filter change (who knows when that was done last)
And flush the coolant and refill.
Check the air filter, and replace the fuel filter as well.
Old Mar 24, 2012 | 09:07 PM
blueSS's Avatar
Drop the pan and use dexron VI forsure
Also one of the first things I did when I bought mine
Old Mar 24, 2012 | 11:57 PM
Trans fluid change intervals are subject to driving environment and conditions. For me, it's 100,000 miles (or sooner).
At your mileage, it's completely worth doing.
BUT, never EVER have the trans fluid flushed unless you want to gamble on that giving you trans problems.
ALWAYS pan drop and filter change.
And for the peeps who think trans fluid/filter changes are the kiss of death.... My '94 Grand Am has 215,000 miles, trans fluid/filter has been changed on two different times by yours truly. Trans works 100% perfectly. It's all about the maintenance.
Old Mar 25, 2012 | 03:12 AM
I absolutely agree, start fresh, you have to know where you stand with the vehicles vital fluids..........
Old Mar 25, 2012 | 03:50 AM
SupplySgt's Avatar
I agree with the above. Change your fluids, but unless you anticipate winning the lottery, DO NOT flush the transmission. Changing it is needed, and you're close enough to 100,000 miles to go ahead and get it out of the way. But do not flush the transmission as you're asking for disaster if you do.
Old Mar 25, 2012 | 09:15 AM
WITH 165,000 ON MINE......I GET A FLUID AND FILTER CHANGE ONCE A YEAR......WHETHER IT NEEDS IT OR NOT....
My bud owns a trans shop so i know its done right!
I wouldnt trust a oil change shop to do work on my trans regardless...
even if it is a fluid filter change....if they use there flushing machine its a reverse fluid unit and tends to crush the filter in the trans! (some are plastic)......
Same thing with the truck with all the towing i do....once a year religiously!
Old Mar 25, 2012 | 07:40 PM
Just get it done, better sooner than later and at those miles you probably won't have any issues
mr5speed
Feb 2, 2013 07:37 PM
Feb 14, 2012 05:02 AM
slinkeey
Feb 3, 2009 10:33 AM
BD
May 4, 2007 02:56 PM
Darkness98
Mar 8, 2006 08:32 PM
