Can you swap out a 3.1 in a 99 to a 3.4 from a 05 Grand Am?
Old May 14, 2011 | 01:01 AM
80sselky's Avatar
After looking at the the small cubic in. differences on these motors I believe I just stick with the 3.1 since the stroke & compression are the same as well as the cam specs. I might possibly look more into taking out the current 30k motor and do the intake swaps as mentioned above, the comp cams MPG/torque cam, and doing the head gaskets, and getting a good tune. Thanks for getting back and confirming on the possible problem of the head gaskets that I had heard about too.
Old Mar 16, 2016 | 12:55 PM
hoodtech's Avatar
Originally Posted by jimmyfloyd
Just for reference, you can use a tuner to change the Final Drive ratio, assuming the computer is supported by the tuner. If you look at the Wiki for the 4t60E and 4T65e, they have the same gear ratios, so the final drive should be all that is needed if you choose to swap. The 00+ impala and monte got the 3.4L with the 4t65e in it, and you could use the axles out of a 98-99 LTZ/Z34 for the 4T65e if you swapped it.
I believe that you can run the 3400 off the 3100 PCM as well, but I am not sure on that.
And I have to agree, if you are going for performance, the 3800 is the way to go.
yes you can i am a student at scc and i put a 3.4 engine and tranny from 2005 monte carlo into a 2003 pontiac that had the 3.1 lt, i was going to you the 3.4 pcm but the theft mod wouldnt allow the car to start, so i had to put the 3.1 pcm back in and it started right up
Old Mar 16, 2016 | 04:58 PM
You probably needed the VIN updated in the 3.4 PCM and then a security relearn.
Nice way to boost a little performance, remove the 3100 and drop a 3400 in it's place
Old Apr 1, 2016 | 11:26 AM
honkbomb420's Avatar
I ran my 99 Monte Carlo with a 3400 swap on the stock 3100 PCM for three years with no issues and plenty of power.I was even able to pass my yearly New York state inspections which require that trouble no codes be present.. Its just the bore size that is different between the engines,The stroke is the same so engine timing is basically the same,the PCM is able to compensate some for air/fuel ratio needs demanded by the slight displacement increase..some may disagree with that but from someone who has done it and had no reliability issue for over 50k hard driven miles i say its fine to run it like that..Is it a perfect tune for optimum performance? NO..But a stock 3100 PCM will adequately run the vehicle until you can have a custom tune done and you will definitely notice a large power increase over the 3100..
ded548
May 6, 2020 09:47 PM
Nas Escobar
Jun 23, 2014 12:33 AM
Sep 23, 2012 01:33 PM
darklady28
May 22, 2010 09:36 PM
jeffsmonte
Sep 25, 2007 08:34 AM
