Can I go with a 2.8 pulley??
Old Jun 25, 2014 | 10:49 AM
JoeD's Avatar
Awaiting Email Confirmation
Default Can I go with a 2.8 pulley??
My mod list Gen V, 3.2, Stage 2 heads, S1X Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 5 Intercooler, CAI, AL 103's Gapped to .055, #105 Springs, 42.5lb Injectors, ZZP Tune egr delete
Old Jun 25, 2014 | 10:52 AM
nitehawkjcb's Avatar
Maybe... But make sure to scan the motor for KR...
Old Jun 25, 2014 | 10:57 AM
JoeD's Avatar
I had it on an drove the car maybe 15-20 miles an it's kicked *** but I'm scared my mods don't support
Old Jun 25, 2014 | 11:34 AM
You won't know what you support until you are monitoring KR and fueling
Old Jun 25, 2014 | 11:42 AM
JoeD's Avatar
Well I can't get my theft deterent off an my local dealer said they can't just turn it off so they have to reflag my whole ecu an I can't do that ill loss my tune
Old Jun 25, 2014 | 12:22 PM
turbo monte's Avatar
I agree you need a way to monitor for kr and fuel pressure drop etc. You didn't list and fuel mods (injectors, pump, etc) also plan on needing a belt wrap because on a 2.8 pulley you will belt slip bad. You can but a tuner like hpt and should be able to take care of the theft detergent stuff. Also if you went from a 3.2 to a 2.8 without a tune I see it being lean and knocking under wot for sure.
Old Jun 26, 2014 | 09:35 AM
Why haven't you at least bought a scan gauge or something then? You've got a few grand in performance mods, but don't have a $200 aeroforce- that just seems silly.
You could also think about it like this- if you do run that pulley without scanning, you could chip a piston and trash the entire engine. Certainly a couple hundred more bucks on a way to monitor KR isn't that expensive in comparison...
Old Jun 26, 2014 | 10:08 AM
JoeD's Avatar
Never said I didn't have a aeroforce nice judgement
Old Jun 26, 2014 | 10:53 AM
We have to assume it, because we are all mentioning that you'll never know if you can run the 2.8 pulley without monitoring KR and Fueling.
If you have the Aeroforce, and can monitor, then you'll know very quickly if you can safely run that 2.8
Most likely it will lean you out though, so make sure you have a way to get the car tuned if that's the case.
Old Jun 26, 2014 | 11:03 AM
I made that judgement because you're asking a bunch of random people on the internet if your mods can support a certain pulley size. We don't know anything about your tune, the general condition of your engine, mileage of the engine, or anything like that- so we would just have to guess based on similar setups.
If you have an aeroforce, a 2.8" pulley, and the right belt (which it sounds like you have all of them)- then you already have all of the data you need to make a much more accurate decision than our guesses. So that's why it seemed like you didn't have a way of obtaining the actual data yourself.
So my follow on question would be- do you know what you're looking for in the aeroforce data? (not trying to be rude- just asking an honest question) If you need help interpreting the data, we can certainly help- but you'll need to provide us with what kind of numbers you were seeing when you had the 2.8" on. If you need to know which parameters we need the data for, we can provide that information also- just feel free to ask.
LennyLeonard
Nov 15, 2016 06:02 PM
Sep 23, 2012 01:33 PM
Dec 30, 2011 08:38 AM
Theflash2515
Sep 15, 2010 07:29 PM
ParrottZ34
Feb 10, 2008 09:06 PM
