Block Heater
Old Nov 11, 2006 | 07:12 PM
Cheesey's Avatar
Default Block Heater
I have a new 2006 Monte Carlo LT, and I just learnt that the block heater is computer controlled to turn on at -18C (0F) when plugged in... This is rather too cold, if you ask me. My GM tech said that if this is over-ridden, then the engine light will turn on. The control is located in the plug end.
My question is, has anybody tried to put a normal end on? Just to see what happens?
Old Nov 12, 2006 | 03:57 AM
z34phoenix's Avatar
Default RE: Block Heater
i would contact a PCM tuning company and ask them if it would modify these values. if not you could always find where the temp sensor is for the heater and throw a resistor in it to make it think its cooler then it really is. i dont know much about block heaters. but if there is a safe way to bypass the temp sensor i would do that.
bbyblue74
Jul 16, 2023 12:16 PM
73bigblock
Dec 19, 2013 11:49 PM
Clarese McConnell
Jun 27, 2013 05:16 AM
73bigblock
Mar 22, 2006 10:09 PM
06MonteSS
Jan 16, 2006 10:51 AM
