another dogbone question
Old Apr 4, 2010 | 10:24 PM
shingding88's Avatar
Default another dogbone question
has anyone done/would it hurt my car to make the dogbones solid mounts? i know its gonna shake like crazy if i do but i just wanna make sure it wont hurt it
Old Apr 5, 2010 | 01:40 AM
Solid poly, or solid as in physically bolt the cylinder head mount to the radiator?
A did see a GP on clubgp that did solid mounts- ie mechanically connected the cylinder head mount and coil pack mount directly to the radiator support.
I could've swore he said it wasn't bad- not too much worse than the hardest polys out there (you've got the figure, the bulk of the engine weight is on the lower mounts- so you're only getting a small part of the total vibration transfer with solid uppers. If you're sticking with a stock cam, and its not your only car- I don't see a problem.
edit- found a thread on clubgp, looks like a few people have done them (one guy even claimed doing all 4 mounts out of steel):
dunno if this will work:
http://www.clubgp.com/newforum/tm.as...anguage=single
Seems like a lot of people in that thread replaced the square mount with either steel or aluminum, but left the round rubber mounts on the other side of the dogbone.
I do know I've seen one before that was physically bolted on both ends straight metal to metal, but I can't find the thread.
Zeke
Mar 24, 2012 06:22 PM
thumpingetocar06
Jan 14, 2010 10:23 AM
2003supersport
Feb 4, 2009 09:15 AM
jay26
Apr 14, 2007 05:50 PM
HaRvArDaLe
Feb 14, 2007 10:18 AM
