ABS, Break and Traction Control lights?
I have been looking around for a wheel hub assembly and have found there are many brands and price points. Another point I see is some have a steel wire clip and some have a plastic wire clip. I would tend to thing the steel is better but I guess I could see how plastic might hold up better. I have seen full hubs from $40 to $300 so any input would be great. Thanks
I have been dealing with this same problem; the ABS, Traction Control and Emergency Brake issue. Sometimes it would happen when raining, then it was random, then just contanstant.
I tracked it down too a grounding strap located under the Air Box. Removed the screw, cleaned up the ground and tightened it back inplace. Problem now gone.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
I went and bought the new Timken wheel hub got it for only $89 but I will have to check on this first before I put it on. I notice that it does come on and off sometimes but mainly stays on. I still have to check the connector on the hub also. I will post when I find out. Thanks for the tip! It could be that strap because I put the CIA in and the new PCM so I could have forgot to put it back on and/or did not put it back on right.
Hope this helps.
Hope this helps.
http://www.knfilters.com/instructions/57-3045_inst.pdf
Used the above link as a reference so you have pictures obviously skip the parts of the actual install of the K&N unit.
6th Gen ('00-'05): ABS and "Service Traction Control Surface" lights won't go out
esquire2021
03-15-2015 09:12 AM
Chris s
01-27-2013 04:30 PM
