95' monte engine swap?
Are you saying the engine isnt great as in its worn out, or you arent satisfied with the performance? If you are looking for a more powerful engine, I wouldnt waste your money on a 3800 swap, you wont be satisfied with its performance over the LQ1 unless you plan on modding the 3800 pretty good. If your engine is worn out and you are just looking for a new engine and want something thats easier to maintain, then I understand the 3800 swap.
You will need an engine wiring harness from a 98-99 monte z34 or a 98-99 lumina LTZ as well as the computer. Once you have that, I would go to the junkyard and find a 3800 engine/transmission combo. The trans behind your 95 z34 will not work with the PCM from the 3800 donor car. You need a 4t65e and you have a 4t60e trans. Plus the 4t65e is stronger.
I looked into switching to the L67, but i also want an engine that lasts a little longer, as in better quality. I agree my tranny is ****. what is OBD2? If i drop the L67 in wont i need to change some off the components like the speedometer?
what is OBD2?
Basically, all 96 and newer cars comply with the OBD2 requirements. It shouldn't be a big problem to change- if you swap to a 3800 (L36 or L67) you have to change the engine's wiring harness anyways to that of a 98 or 99 monte Z34- so that upgrades the entire engine bay to OBD2. All you've got to deal with is running the wiring to the OBD plug under the dash (its on the drivers side, its a longer rectangular plug that hangs open just under the dash).
The speedometer has nothing to do with the engine swap- and anything you'd have to do to put in an L36 would be about the same for an L67 anyways.
Just get a complete L67/4t65HD powertrain, get a 98/99 monte Z34 engine bay wiring harness (about $150 or less)- get zzp's L67 swap wiring kit (about $20, just two plugs)- and fluids and a few other things, and you're set. Its 95% bolt in (other than the axles which is explained in the swap how to)- and 98% plug in (other than the L67 swap conversion wiring which is 2 plugs, and your OBD2 plug under the dash). Doesn't get much easier than that.
crent
Sep 25, 2019 05:43 PM
Budsjlm
Apr 3, 2012 05:43 PM
retr0kickz
Jun 22, 2009 10:05 PM
99montecarlo
Jun 17, 2009 03:33 PM
